BFL13
Jul 30, 2018Explorer II
2oldman wrote:
Is the little red power wire to the shunt hooked to + ?
No positives on the shunt. However, if the OP has the display pos to a different battery from the one the shunt is on, then he will see voltage of that battery but no amps.
I don't have a Victron. The Trimetric has B1 and B2 where you can use B2 for a second battery and only get the voltage for that one.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
