CA_Traveler
Jul 30, 2018Explorer III
Does the shunt require an specified end to end connection so that the polarity is correct going to the meter? My Trimetric requires the correct polarity wiring to the meter.
Have you cleaned the cable connections? It could also be the cable or the meter. Have you contacted Victron?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
