dieseltruckdriv
Jul 30, 2018Explorer II
shastagary wrote:
are you sure it is set up correctly in the settings is it set to the default shunt setting of 500amp and 50mv in the settings it is adjustable to be able to use different shunts. manual
I did check that, and I have done two factory resets, and that causes it to default to 500/50. I was hoping it was a menu setting problem that I had messed up, but no such luck it seems.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
