dieseltruckdriv
Jul 30, 2018Explorer II
Donnoh wrote:
I just bought one of these but haven't installed it yet. If I were you I would be suspect of the cable between the shunt and the display. Have you tried another cable yet? The voltage displayed may be taken from the display supply and the current and battery temp function come from the shunt.
Did you purchase a battery temp monitor? If you did do you get a temp reading?
As a former PLC and automation controller programmer I feel your pain.
I have tools that I can test the cable, but I trust the cable. How often do phone or ethernet cables go bad. Plus the display works perfectly.
I did not get the temp monitor, the 700 doesn't offer it as an option.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
