TenOC's avatar
TenOC
Nomad
Aug 20, 2014
Voyager AWM930/AWM93W radio comes on randomly ??
I have a Voyager AWM930/AWM93W radio in my TT. For some unknown reason it comes on randomly. Some time at night. . :M, . . some time in the day.
I have put a black tape over the remote sensor and have use the red button to reset the radio.
Since I am a full timer, I am in (or near) the TT most of the time when it comes on. Some time no one is in the trailer.
Any suggestions ??? . . . :h
  • If you are positive it has no weather alert, then this does happen sometimes. The only sure fix is to install a On/Off switch and mount next to the cabinet by the radio. Doug
  • n7bsn wrote:
    Check the alarm(s) ours turns on if someone mixes the alarm button up with the power button
    Alarm is off
  • Check the alarm(s) ours turns on if someone mixes the alarm button up with the power button
  • the bear II wrote:
    Some electronic devices come on automatically when there is a power outage and the power is restored. This also happens if the power drops and then picks up again (power hit/spike). Perhaps there is a drain on the power system that looks like a power outage to the radio. The drain could be in the park power or something in your RV.
    If the radio is equipped with a weather alert function, maybe it is getting confused by weather alert like signals...military, aviation..
    No Weather alert.
    The radio is 12V so the 110V A/C should not effect it ???? The battery should smove out any spikes.
  • Some electronic devices come on automatically when there is a power outage and the power is restored. This also happens if the power drops and then picks up again (power hit/spike). Perhaps there is a drain on the power system that looks like a power outage to the radio. The drain could be in the park power or something in your RV.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
