toban's avatar
toban
Voyager rear camera doesn't work- sort of? Need help.
I have a 2004 DSDP. On the way home this past spring from AZ, my voyager AOM 711 rear TV monitor quit working. The screen was black and I could smell a metallic scent. It gets very hot behind the dash with the heat on through the vents plus the heat from the monitor itself so I think it just over time burned out.
I pulled the monitor out and found the 5AMP fuse was blown too. I talked with ASA Electronics who make the monitor and they said over a period of time these monitors can wear out and short. I bought another monitor AOM 713 and put it in and replaced the 5 AMP fuse. They said the old harness should work. The monitor works but now I have no picture from the rear camera. I said sort of because you can see some but is a very poor picture. Basically, you can't make out anything. The manufacturer said to wire in the new harness in that came with the new monitor. I haven't done that yet but am going to do this shortly.
Has anyone had trouble with the rear camera like this? I don't know how I can retrieve the cable through the back cap as it's siliconed in big time. Newmar told me there is a 3 ft cord from the rear camera and is plugged into the main cable that runs to the front monitor.
Your input would be appreciated.
Toban
1 Reply
  • The manufacturer now says to try the new harness that came with the new monitor which I will try.
    Has no one out there had a voyager monitor short out? I have had this motorhome since new in 2004 and this is my second monitor although the first one was a different brand. Newmar put in the voyager one that just quit on me and has affected the operation of the rear camera for some reason.
    Toban
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
