DrewE
Jul 17, 2015Explorer III
It should not go dead in a couple of days with a good battery. Depending on your climate conditions and driving habits and so forth, 2-3 years might not be unreasonable for a car battery's lifetime. That said, I would expect somewhat better life around Calgary than in hot southern climates; in Vermont, I seem to get five to seven years or so. It does help that I don't generally need to go on short trips where the battery doesn't have a good chance to recharge completely.
I would check to be sure you don't have unexpected loads on the battery. Sometimes they can be very hard to track down.
It's certainly also possible that the other battery was defective or broken. If it had been discharged completely several times, that in itself could make it quite weak. Car starting batteries do not handle deep discharging well at all; they're optimized instead for a quick burst of peak current (to start the engine).
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
