EMD360's avatar
EMD360
Walmart Battery
I have decided since I can't keep from inadvertently running down the house battery too far and destroying them, I will just use Walmart batteries. At least they are not that expensive to replace.
I bought a Group 29 DC on the road today having them test my old battery from 5/13 as dead as a doornail. Kind of easy to find a Walmart these days. They don't always have stock but I guess I was lucky. I was worried about the battery before we left, but when it didn't even turn over the generator after driving 4 hours, I knew it was toast.
On the way to the Great Sand Dunes, I stopped at the Salida Walmart and got a new battery. It is working great. But I know it will only last a couple of years with my use. Maybe I should put in a disconnect as I think there are loads from the propane alarm etc. that drain it totally when I don't have it plugged in, or maybe my original equipment converter is destroying the battery while charging it. This is my third Walmart battery in about 4 years, the first one replaced while still under warranty.
Before that I had used AGM's and before that two Interstates that came with the RV. Some folks have only had one battery in all that time! Oh well.
