SDcampowneroper
Feb 24, 2018Explorer
profdant139 wrote:OK, ? suspect restriction in the heat exchanger tube, like a mud dobber nest. That would cause a backpressure air flow that would cause the flame to blow back until the tube is heated enough to create draft. ?
SDcamper, we found that this was happening even at sea level, so I ruled out the air supply issue. But if this re-occurs, I will have to play around with the intake.
