profdant139's avatar
profdant139
Explorer II
Feb 23, 2018
Water heater flameout: cleaning the electrode
My five-year-old Suburban water heater started to act up: it would light, and then go out, and relight, and go out, several times, until it would finally start to burn steadily. I did the usual Google research and discovered that this is fairly common on home water heaters, when deposits build up on the ignition electrode.
Surprisingly, I couldn't find any "how to" postings on this site (or anything specifically about cleaning RV water heater electrodes), so I decided to document the process. (If I'm repeating something that's in the archive, please forgive me.)
The first thing is to remove the shroud or cover over the burner assembly. On my water heater, the shroud was attached with three screws. This is the center screw:
Click For Full-Size Image.
This is the right side screw (which was kind of hard to see):
And this is the left side screw:
Once the shroud is off, the burner assembly with the electrode is very easy to see. In this picture, I have already removed the burner. Frankly, I don't think it was necessary to do so, but I wanted to make sure that I would not damage the electrode when removing it:
I then slid back the orange rubber end-cap to gain access to the screw. I unscrewed the single screw holding the electrode in place (use a quarter inch socket or wrench). Finally, I rotated the electrode by 90 degrees to extricate it carefully from the bracket:
When I pulled out the electrode, I could see a grayish powdery deposit on the tips and the sides of the electrode. This picture does not show the deposits very clearly:
I then took a small piece of 100 grit sandpaper and gently scuffed away the deposits on the metal prongs:
Reinstalling the entire thing was pretty simple - just reverse the steps.
Problem solved -- it works fine now.
  • ScottG wrote:
    Carb cleaner works too!
    X2 on carb cleaner.
    I used DeOx-it for electrical connections.
    Mechanical abrasive would be my last choice
  • Scott, I wanted something that would fit between the prongs -- not sure a brass brush can get into that gap?
  • Nice job! So many others would needlessly replace what is a perfectly good part.
    Just a suggestion but next time get yourself a brass brush to clean it. Does a great job without wear or possible damage.
  • Sigh. I posted this in the wrong place -- should be in DIY. Very sorry for the inconvenience. Dear Moderator, can you rescue me from my own incompetence?
  • Yes -- wow, you are fast -- I clicked edit to add the tag line, and you had already posted!!
