Old-Biscuit
Sep 04, 2013Explorer III
Electric switch ON and no water in WH tank....usually means burnt out element.
Both just for giggles......
Check the t-stats. Each heat source (electric & propane) have their own set (normal & ECO--high temp).
The ECO (high temp) has a reset...if tripped electric or propane will not heat
Reset(s) are under rubber cover.....push each one hard to reset
Probably still have a bad electric element BUT if gas ECO is tripped it could be problem with no spark (no power)
Service Manual Link
Service Manual Link
