MadMav
Sep 05, 2013Explorer
Update. Ohmed out the element and it was good at 10.6 ohms. Took everything appart and cleaned what I could. Double checked the resets and all the connections. I can hear the power when the switch is on, so we are ongoing testing for the electric heat today.
I discovered that water heater is on a set of switches that it shouldn't be. The not only is there the CB on the water heater, and in the CB panel, the electic is once again on a big 120v lighted swtich. This is usually reserved for the gas function of the water heater from my experiance. I also found that the gas funtion of the water heater is on a tiny lighted switch labled for the tank heaters. Man this thing is wired backwards.
I at least got the hot water going off the gas yesterday and all seems to work fine there. I am having them shut off the gas portion today and see if the electic can maintain the heat after everything was cleaned and reset.
Thanks for the suggestions. Hopefully we got this knocked out.
Mav
Mav
