rhagfo
Jan 31, 2022Explorer III
dufferdj wrote:
Water heater (Atwood GC6AA-10E) works as expected on propane, but will not heat the water on the electric setting. I have reset the circuit breaker, checked the thermal cut off (fuse) for continuity, pulled/checked the 2AMP fuse in the circuit board, checked the green ground wire for a good ground, burped the water tank, checked all wire connections and even replaced the circuit board as I had an extra from earlier issues. As the RV was sitting in the storage lot I had to run the generator as an electrical power source, but I let it run for about 60 minutes. What am I missing? TIA for any and all suggestions....
Sounds like the only thing you didn't check was resistance on the heating element. I am not sure what people consider normal, but I know if bad it will show open.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
