memtb's avatar
memtb
Water Heater Quit Working on Propane
Recently, while boondocking, our water quit working on propane. We got by for a little while, by using the generator. But....during some “down-time” ( just relaxing), spent some time “troubleshooting “.
The gas solenoid was receiving power and “clicking”, the igniter was “sparking”, we had gas to, but not through, the solenoid.
Figuring the solenoid was bad ( sticking or failed) and couldn’t replace until we got home....I decided that I’d work on it. The worst I could do was break it!
It required special torx bits that I didn’t have, for the disassembly, so....I decided to spray into the gas in and out ports with silicon spray. Initially....no improvement. But...after a few hours, I decided to give it another start attempt....we got ignition.
It’s now worked flawlessly for a week. I’ll replace the gas solenoid valve, and keep the old one as a spare.
Desperate people do desperate things.... and sometimes it works out! ;)
  • Old-Biscuit wrote:
    Sounds more like gas orifice was clogged and the spraying helped clear/clean it
    Very possible. I was just guessing that the solenoid was sticking....but pluggage may have been the issue. :h
  • Sounds more like gas orifice was clogged and the spraying helped clear/clean it
  • Check the ground wire where it attaches to the solenoid mounting bracket.
    I ran a separate wire from the ground attachment to the ground in the wiring harness. I didn't like the use of sheet metal screws to make good contact.
  • Before you replace the solenoid, check the ignitor assembly connections. If they are OK, replace the assembly. That is a lot cheaper, quicker and more prone to failure than the solenoid.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
