BFL13's avatar
BFL13
Explorer II
Jan 29, 2019
Water Heater UPDATE 3
UPDATE--it was the "air shutter"
UPDATE 2 - replacement burner in --all fixed 8 Feb
UPDATE 3- Smokey exhaust 15 March
This is for the Atwood GH6-6E direct ignition gas only water heater in the 1991 MH.
Cleaning out the gas pipes and orifice was straight forward, but I believe the gas valve part is partly clogged up from the way it acts. I can't clean it out with it closed.
From the manual, it seems it has a high limit switch and ?two? gas valves. Not sure which wires are which to apply voltage to. I am thinking I can use my small 2 amp charger with its clamps that is a constant 13.4 voltage
Can you keep it open with some voltage on whichever of the several wires go on it, so you can squirt mineral spirits into the inlet side and see it come out of the outlet side?
some advice in here around page 24 area.
http://bryantrv.com/docs2/docs/atwoodwaterheater.pdf
Having RV issues? Connect with others who have been in your shoes.24,247 PostsLatest Activity: May 14, 2025
