StewB
Oct 25, 2015Explorer
Water level
How much acid should be above the plates on a lead acid battery?
Thanks for any input
Stew
Stew
Old-Biscuit wrote:
I use one of these.......fill it with distilled water, insert it into battery cell, push down and water flows/stops when level reaches bottom of opening.
Easy..simple
Old-Biscuit wrote:That's pretty neat. I'll have to look this up.
Easy..simple
MEXICOWANDERER wrote:
The CORRECT LEVEL is that which is low enough to prevent purging at max charging and temperature. It is pre-determined by the manufacturer according to cell dimension and plate percentage fill. Start with a level 1/8" above the plates then check it again after max charge rate charging. If it did not rise a lot add a bit more water. Simple enough.
Old-Biscuit wrote:Yup, putting that on the "immediate wish list". They work great.
Easy..simple
