dougrainer
Apr 19, 2017Nomad
Is the water pump running at speed when this happens or does it surge and cut in and out? Depending on how many faucets are open the Pump surging is normal. Your problem is normal for some RV's depending on the water Pump and how it operates. The Water Pump pulls significant amps and can cause voltage fluctuation problems. Regardless of how many batteries you have. When on Shore Power, the Power Converter keeps the DC voltage pretty static at 12.9 to 13.1 with no voltage variations. Doug
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
