Tbonez's avatar
Tbonez
Water Pump Fuse
Anyone have a clue as to why I am blowing the fuse on my water pump. Replaced it and immediately blew it again. Camper has been in storage for a month, pulled out to winterize and found the fuse was blown. Replaced and blew again, did this twice now. Help.
  • Possible pump is frozen up and causing the blown fuse?
  • Pump controller IF you have multiple ON/OFF switches for pump
    But if you have just 1 ON/OFF switch for pump....then motor is shorted OR the wire from DC Dist Panel to pump is shorting out.
  • You may have a problem with the pump controller if equipped.
    Disconnect the pump, then test the system. If it blows locate the pump controller.
    Pump controllers of various type are used with switches to turn pump on or off from different locations.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
