ferndaleflyer's avatar
ferndaleflyer
Explorer III
Dec 14, 2021
Water pump help----maybe
Went South a week ago and it was working fine but after a couple of days on the camp ground water we unhooked and our on board pump seems to have a problem---the pump is only 1 year old. This is a 1998 Monaco. It has a switch in the outside bay, in the bathroom and on the control panel. None of these work (red light does not come on) Only fuse I know of is in the panel over the bed and it is good+I changed it anyway. That fuse is for the water pump and the control panel. I checked power to the one in the bathroom and the one outside and for some reason it shows about 6.5 volts. Everything 12 volt on the up front control panel that is 12 volts works as does the light on the same panel as the pump in the bathroom. I will bypass everything tomorrow and make sure the pump is working. Help!
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Nov 11, 2025
