olympicman's avatar
olympicman
Water pump switch question
I am in the process of installing the SeeLevel tank monitering system. I bought the monitor that has the water pump switch and the water heater switch.
My current system uses an Intellitec Mpx Low Side 10 amp Latching controller to make the 3 momentary switches "push on push off both same direction" work.
The SeeLevel switch is not a momentary switch it is an on off switch. Will this work with pump controller with no problems?
