wbwood's avatar
wbwood
Water pump
This year when I winterized the motorhome, I goofed and forgot that the water pump was on and hit the check valve on the city water inlet on the outside. Had to replace the city water inlet due to the check valve messing up. After I replaced it, I went to run some more antifreeze through the lines. I turned on the pump and you can it hear it running, but it's not sucking up any of the antifreeze.
Easy fix?
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
