evy
Apr 18, 2016Explorer
Water tank question
Hi everyone,
I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250.
I have some questions about the clean water tank.
I don't want to install a 12v level indicator, I don't remember where I saw this but I saw a picture of some sort of bypass with clear tubing, the water would rise in the tubing at the same level inside the tank. or maybe was it between the city inlet and the vent? because I'm thinking when the pump is activated it will suck air from the bypass? I have no idea lol.
I also want to know how I will clean the water tank? I thought of getting my hands on a marine hatch, maybe that would work? is there a cheaper simpler way?
by the way how often do you need to clean the water tank?
A friend also told me I should install a bottom drain in the tank for emptying it without using the pump, is that a good idea?
how and where would I add it?
Thanks for any info!
