Skibane
Nov 14, 2021Explorer II
6.7lPSDFORD wrote:
All the batteries combined were making 8 volts.
Yep, it almost sounds like the 6 volt batteries are connected together incorrectly.
If all 3 of them are connected in parallel, you'll only get 6 volts from them.
A pair of them need to be connected together in series to get 12 volts - and the third one can't be used for anything, since you don't have a fourth battery to connect it in series with.
If your batteries are wired to only produce 6 volts, it's possible that the converter is trying to charge them up to 12 volts - and only making it up to 8 volts before the fuse blows.
Check your battery connections.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
