kx125str99's avatar
kx125str99
weekend warrior power surging
hey guys i have an 03 weekend warrior i have had for about a year. i have been having a problem with power every once and a while. when i am camping at least once a day my whole trailer lighting surges for less then a minute and then it is fine again. i am clueless on what it could be. anyone have any ideas?
  • i checked the ground it seems to be pretty good. i thought it was the converter but wanted to check. thanks guys
  • kx125str99 wrote:
    They are 6 volt batteries. It did it with the batteries I had before too. When it plugged into power and also with generator.
    That just about puts the nail in the coffin. I'd start shopping for converters. The good news is you'll probably get a much better one than the one you have. I suggest Bestconvert.com and take a look at Progressive Dynamics Ind. converters.
  • They are 6 volt batteries. It did it with the batteries I had before too. When it plugged into power and also with generator.
  • Have the batteries load tested by a auto store so that you know they are not part of the problem.
  • Test battery and then test output of converter. If it's not close to rated output, replace it. Mine just surged in 1 minute cycles and died this past summer.
  • If it's the 12V lighting doing that then it's the classic sign of a converter going bad.
    First check your battery to make sure it isn't shorting internally and very low on water.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
