alliemac9's avatar
alliemac9
WFCO Converter/Charger Dead? How to tell?
Our RV is a 2007 that we purchased in 2010 (new from dealer, so it sat for a few years). So, it's had four years of use and we took it out last weekend for the first trip of the season and had some low battery issues - not enough to cause problems, but we'd never seen the batteries sit on "low" before. I thought the batteries might be at end-of-life since they are from Feb 2010 as well.
However, it looks like the converter/charger may not be working. When plugged in in storage, we used to be able to hear a noise when charging, and now we have low batteries and no noise. So far, we've checked the breakers, but not the fuses (assuming there are fuses).
It is a WFCO WF8955AN. Is four years of use (plus three sitting) the likely lifespan for a converter? Is there anything else we should check before calling it dead? If it's dead, is there a recommended replacement?
I'm planning to put a solar system on the RV this year - the panels are being shipped (632 watts!), but I still need to purchase the rest of the components, in case that somehow factors into recommendations.
Thanks in advance for any recommendations!
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 05, 2025
