Golden_HVAC
Mar 14, 2015Explorer
Hi,
If you have #4 wire going all the way to the trailer, then a 100 amp fuse is the max size that should be used. You will not get more than 50 amps to travel between the two 12 volt batteries. You will need a very oversized connector, like a forklift battery connector to get more than a few amps from the truck to the trailer. Look for a 50 amp rated 'anderson connector'. It will handle 75 amps without getting warm, and is rated at 50 amps when plugging in and out all the time without a problem.
The wires going through the factory wiring harness are probably #12 wire - rated around 20 amps, and with that distance, probably will never see more than about 10 amps going into the trailer battery.
By connecting a wire directly to the alternator, you will get a full 14.2 volts, while the battery probably only has about 13.5 volts.
Good luck,
Fred.
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
