- bpoundsNomad
suprz wrote:
...5/8th hole i drilled into the square tubing
Guess that drill bit wasn't really 5/8". 15mm maybe? Originally 5/8" but worn out maybe? - wanderingaimlesExplorerIf this is something you did for an add on or modification, drill the hole out an additional 32nd of an inch to allow room to slide it in.
No set of holes on this stuff is normally so perfect that it has no slop to allow for slight variations in alignment, from surface dings to rust, you always want a little wiggle room. - suprzExplorerThe hitch is on the rv and the pin fits every other attachment i have, cargo baskets, motorcycle carrier, etc.. I am building a custom kayak carrier, and the pin, and other pins i have do not fit into the 5/8th hole i drilled into the square tubing
- LynnmorExplorer IIIt should be 5/8", either the hole is messed up or you bought a cheap pin that isn't to specification. Try the pin separately in the receiver and the shank if you haven't done that already.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
