mrad's avatar
mrad
Explorer II
Jun 14, 2021
What's the best way to get RV anti-freeze out of system.
What is the best way to get rid of all the RV anti-freeze from the system? Last year when I winterized, I drained the water heater and had the antifreeze bypass it. this spring I opened both low point drains and opened the faucets in the upstairs bathroom of the 5th wheel. I then hooked a hose up to my city water connection and ran all spickets (except washer dryer connections) until clear.
We have now spent 3 days in it, and are having the pink stuff come out of faucets and toilets when we first turn them on, along with the odor.
  • Nothing is foolproof if done improperly, air or antifreeze. This applies to blowing out your lines as well. Done properly it is foolproof as their is no water left to freeze.
  • Lantley wrote:
    Sjm9911 wrote:
    LouLawrence wrote:
    Don't use anti-freeze next time. Drain the fresh water tank, and black and grey tanks. Use an air compressor to blow the fresh water lines and then just throw a bit of anti-freeze in the P-traps to get rid of or dilute the water enough to prevent freezing. Next year you are good to go by just filling the tanks and heading down the road.
    I had another guy sware by this , untill his water pump broke. It depends on the climate your in. And while blowing out will work 90 percent of the time, its the other 10 percent that gets ya.
    Exactly Anti freeze is foolproof, other methods are not
    IF you know what you are doing Blow out is 100% effective. I have over 42 years and thousands of RV's I have winterized by using air to blow out and have NEVER had a failure. The ONLY places I install Antifreeze is in the Clothes washer drain pump and the Dishwasher drain Pump which are not connected to the fresh system. Doug
    Sounds like he forgot to drain the water pump. You will always have failures if you aren't thorough. The water pump must be drained separately from blowing out the lines. I know someone who always winterized by pumping RV antifreeze through his system. One year, he forgot to do the outside shower and it broke. That doesn't mean that RV antifreeze is a bad choice. It only means he wasn't thorough.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
