Old-Biscuit
Jul 02, 2013Explorer III
Francesca Knowles wrote:BurbMan wrote:Francesca Knowles wrote:
The battery on a camper (or trailer) has nothing to do with vehicle brakes. It's strictly for use by the camper/trailer.
It supplies power to all the 12volt systems in the camper- but if you have nothing powered by 12 volt, get rid of it.
That's some BAD advice right there! If the camper becomes detached from the tow vehicle it loses the 7-pin connection and the power it gets from the tow vehicle. The breakasway switch will activate the brakes BUT only if there is a battery to power the brakes. This is REQUIRED BY LAW. You will see even utility trailers, if they are large enough to need brakes, they will have a battery even if it's a 12v dry cell.
:h
Breakaway switches must have their own dedicated source of power and can't be powered by the trailer battery.
Not that it matters in this case, since we're talking about a camper.
Breakaway switches are just that....a switch was allows the trailer battery (or a small battery in switch....for trailers that don't have a battery) to supply 12V DC power to the trailer brakes in the event of a 'break-a-way'. Battery supply to brakes must come from on-board battery as it will be the only source when trailer is bouncing down the road.
And what is a 'camper'.....OP didn't specify
Truck camper, towed camper etc.
Campers have on board batteries so that they can be 'self contained recreational vehicles'
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
