69_Avion
Jul 03, 2013Explorer
I would have an on board battery even if I had a modern converter. I can't imagine only using my camper in a campground with power, but I'm sure there are folks that like it that way. My camper is older and I have a small battery charger, with no modern converter. As stated above, how would you run a modern refrigerator while on the road with no 12 volts? My original refrigerator and water heater didn't require 12 volt power, but when I rebuilt the camper I put in modern electronic ignition. I don't regret that at all. It is much nicer.
So to answer the OPs question, if set up properly you can run a TC without a battery, but with modern appliances you can't use them on the road without the 12 volts.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
