- Jayco-noslideExplorerApologize for my smart alec manual comment but I mention it because many folks(especially men) never look at a manual for any product. I'd have to check but I think it is in my manual for our 2003 Itasca. Yes it may cover multiple models; nevertheless, it has helped me with many issues. The previous owner showed me the drain handle and it is hard to find.
- BFL13Explorer IISome RVs have a drain valve on their water tanks besides the outlet hose to the RV water pipes to the sinks etc. But some don't. They just have the outlet pipe near the bottom of the tank to use as a drain.
The ones I have seen with a drain have an extra hose running out near the bottom of the tank, with a turn knob that goes along or across that drain hose. You can get at that from above lifting the dinette seat or whatever you have to do.
To drain the kind with only the outlet pipe which is not quite to the bottom, just do the best you can using the "low point drains" and then put your pink stuff in.
Actually, I don't use any pink stuff in our climate, since the worst that can happen is the little water left in the tank will only expand upwards in the mostly empty tank where there is plenty of room when it freezes. - bikendanExplorer
Jayco-noslide wrote:
Owner's Manuals are really interesting.
There is virtually NO owners manual that would have the location.
Nearly all RV owners manuals are generic, with no model-specific information. - smartyExplorer II
statements like this have no place here. If you can't be helpful maybe you should not post anything... - ksg5000Explorer IIYour rigs new enough that you should be able to pull into any dealer who sells coachman and find someone who will know.
- Beverley_KenExplorerLook around the sides of the fresh water tank, near the bottom of may actually be on the bottom of the tank, depending on your individual model. Ours is near the water pump, but a separate fitting off the tank, it then has a separate valve before leading to the 1" drain pipe to the bottom of the RV. Our old trailer just had a screw cap on the drain pipe.
On ours, the pump and fittings are on the opposite side of the RV from the fresh water fill and vent fittings.
Ken - Jayco-noslideExplorerOwner's Manuals are really interesting.
- There is no way anybody can help you with the information you provided. Provide the complete make and Model of your camper. Then somebody that has one can tell you where the drain is.
- cavieExplorerlook at your FW fill port. The drain for the tank will be under the 5er very near the inlet. It will have a cap or a valve. Next to it may also be a vent/overflow line with no cap or valve. It May not have a vent out the bottom but a vent at the fill valve Incorporated within the fill valve opening.
- Roger10378Explorer IISome times it is a cap instead of a valve.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
