maillemaker's avatar
maillemaker
Where to buy track for window curtain?
I have a 1990 Winnebago Warrior.
The track for the curtain at the front of the cabover bed is broken.
Here are pictures of the track:
http://imgur.com/a/jU6DF
Does anyone know what this is called and if I can buy replacements anymore?
Thanks,
Steve
  • We have the same in our MH. I bought the new tape with the clips for new curtains at tweetys.com who had the cheapest rate. I am pretty sure they had the track also.
  • With what wa8yxm said, might add a couple of small screws through predrilled holes either side of the break into the wood it is attached to.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    You should be able to get it at most larger RV dealer stores or at Camping World. and Smaller RV dealers can order it.
    HOWEVER. the break is clean so why not just fix it.. Here is how
    if you look at the photo and imagine the track as a lower case "t" sitting on it's side. the "Track is the top of the "T" (on the right as you look at it)
    You can line up the two ends of the broken piece, put a THIN layer of GOOP on the end and press it together and fix it (Use a vice or other clamp to keep them aligned) let dry for a few hours then glue a craft stick to the back side (Left in photo) to add strength.. Let dry overnight and re-install CAREFULLY 2 person job. At least till you find a replacement.
  • Try RVdesigner.com I'm not sure if they have that particular one, but they stock several types and all of the hardware. Poke around their website some.
    RV Designer hdwr Clicky
    Bill
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
