allbrandauto's avatar
allbrandauto
winegard traveler satellite dish
bought a winegard traveler slimline dish 5 years ago reception on sat. 101 is 95 in clear sky sat.103 is 59 sat.99 is 80 has always been that way camp next to people that has same set up as me and all the sat.are in the 90s when it rains loose reception in hd what can I do
  • The numbers on mine generally agree with Bill's. As he said some play is normal and also correct that you have 3 LNBs in one unit. Another possibility is that the arm is slightly bent. The LNB as well as a new dish are relatively cheap. I am assuming that you have checked the connections and that they are clean and fully seated at the base.
  • Some play is OK and it cannot be tightened or adjusted. You do not have a single LNB. You have a single LNB that contains 3 LNB's. 2 KA band for 99 and 103 and 1 KU band for 101.
  • thanks bill there is some play in the base has been that way since new can it be tighten my problem is on sat 103 it has a single lnb
  • Bill.Satellite wrote:
    This can happen if the dish is ever so slightly bent or the LNB housing has 1 of the 3 LNB's bad. You can try replacing the LNB with a new one (cheap) and if that doesn't work you can try a new dish reflector. Winegard has also had some units where the base "slop" is too much and while it tunes in well, just a bit of wind or vibration (walking around, closing door) can shift it ever so slightly off signal. There are also multiple transponders and they vary in strength. You want to pull up the signal meter that shows all of the transponders and not the signal strength meter that only show 1. Let me see what I am getting right now.......hang on.......Still waiting for a commercial.....OK, here we go. (Atascasdero, ca)
    101 mostly 95+
    99 (ca) 86+
    99 (CB) 82+
    103 (CA) 84+
    103 (CB) 81+
    Ignore everything with (s) at the end...spot beam and doesn't mean much.
  • This can happen if the dish is ever so slightly bent or the LNB housing has 1 of the 3 LNB's bad. You can try replacing the LNB with a new one (cheap) and if that doesn't work you can try a new dish reflector. Winegard has also had some units where the base "slop" is too much and while it tunes in well, just a bit of wind or vibration (walking around, closing door) can shift it ever so slightly off signal. There are also multiple transponders and they vary in strength. You want to pull up the signal meter that shows all of the transponders and not the signal strength meter that only show 1. Let me see what I am getting right now.......hang on.......Still waiting for a commercial.....OK, here we go. (Atascasdero, ca)
    101 mostly 95+
    99 (ca) 86+
    99 (CB) 82+
    103 (CA) 84+
    103 (CB) 81+
  • You can do nothing. It is all in the programing Winegard supplies. If this is on Directv you might look at a new LNB,arm and reflector. But I doubt that will fix your problem.
  • I've been setting up a Slimline dish for years and never have I gotten all sats in the 90s. Have you actually seen these reception numbers on your neighbors' systems?
    I don't 'loose' reception in rain but in heavy clouds, occasionally.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
