jaw7yonto's avatar
jaw7yonto
Explorer II
May 21, 2026
Wiper Fluid in Water lines
All right, I was an idiot and accidentally put wiper fluid in my potable water lines during the winter. I checked, and it does have methanol in it. I have a pop-up trailer with a water tank below, a water heater, water pump, and then lines to an outdoor shower and a faucet inside.
There is an obvious wiper fluid smell coming from the water. I have flushed the system 9 or 10 times by filling up the water tank with fresh water and running it through the whole system. I've run a flush with some vinegar solution as well as a bleach flush. The smell has definitely gotten less, but I can still smell the chemicals.
Am I totally screwed or is there a way to save my water system from having to be completely replaced?
  • Drink bottled after til the smell goes away?
    I mean, a popup water tank can’t hold much more than enough to do dishes.
    • Lwiddis's avatar
      Lwiddis
      Navigator
      No long term disbursed camping in a pop up.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      you would be surprised haha
      I had an issue where I had a "taste" and I flushed it like 30 times and wouldnt go away untill I used the Sodium Percarbonate on it.  now I just do that every two or three years as a maintance thing, or sooner if I think I need to.
  • Someone said they had a source for cheap vodka? Could help me get out of a financial predicament.
  • Mixing household bleach with methanol can produce methyl hypochlorite, and may generate toxic gases such as chloroform, hydrochloric acid, chloroacetone, and dichloroacetone.
    in my opinion your best bet is time. Blow out the system completely of every last possible trace of liquid. Methanol will evaporate rather quickly, heat will help that process.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      True, but not after flushing out all the meth…. Disinfect the piss out of it and see if you can smell (anything, lol) after a high dose of chlorine.
      StirCrazy
      Moderator
      to late for that he already flushed it a bunch of times.  its not the methanol thats flavoring the water lines its the "other additives" they put in windshield washer fluid that are doing that.
      • Grit_dog's avatar
        Grit_dog
        Trailblazer
        My bad. Missed the bleach n vinegar part.
        Ya idk.
        I don’t add stuff to potable water lines that isn’t plain water (or some chlorine to disinfect). so was spitballing.
  • your going to need to sanitize your system.  you can do a mix of 100% bleach (1/4 cup per every 15 gal) fill everything up including your lines and let it sit for 12 hours, then drain and rince till the bleach taste is gone, or I dont use bleach any more I use Capt Phab purge tank clenser.  its costs more than bleach but the time it saves me I find valuable.  it disenfects and cleans but you only have to rinse once, instead of 10 times to get rid of the bleach taste.
