Billinwoodland's avatar
Jun 21, 2016
Wiper module or relay location F53 chasis
Hi friends. I have been chasing a wiper issue. They became non-functional after getting crossed while running. I turned them off, but they continued to work to complete their cycle, then I smelled that "electrical burn" odor in the coach before I found a safe spot to pull over and untangle them. The motor works fine, but there is no power to the fast or slow wires to the motor. The fuse in location #11 is fine. I assume there is either a relay or module sowmewhere in the coach, but for the life of me I can not find the location. Trying to trace the wires from the engine compartment is a nightmare. Does anyone know where the physical location of the relay or module is? 2008 Monaco Monarch, ford chasis.
Thanks fellas!
Bill
  • dougrainer wrote:
    The module is where the Steering column meets and goes thru the floorboard on the inside. There are several Ford modules mounted on the firewall at that point almost on the floor. Doug
    Ok, thanks. I'll take a look this weekend when I can get out to the storage place.
    Thanks
    Bill
  • The module is where the Steering column meets and goes thru the floorboard on the inside. There are several Ford modules mounted on the firewall at that point almost on the floor. Doug
Having RV issues? Connect with others who have been in your shoes.24,359 PostsLatest Activity: Feb 07, 2026
