kioticoachman's avatar
Jul 18, 2018
Wired Rear View Camera ??
Dear Friends ... Have an older RV that came with a RVS Camera System. However, in need of input from our Forum Family. The RVS camera system appears to be in need of a replacement. A few questions, if you will?
The current system is a wired system. Need a system that can be turn on and operated while traveling as I need to keep track of all vehicles directly behind & up close. Also would like a Wired unit that can clearly detect traffic in after dark driving.
I have a monitor that was nicely installed on dash that can be used to view rear or back up situations. What do our RVers use or suggest I replace this Unit with? Hope this helps? Any and all suggestions would be very much appreciated. Thank you very much! :)?? KC
  • Johno02 wrote:
    I checked about a new system me time ago, and was told that whatever was installed , there were adapters to allow the new system to use the old cables and plugs. Hope that helps you some. Most systems are wired to be on with the ignition, so that is not a problem. Whenever you are driving, it is on. No need to turn it off. Most larger RV supply stores will have whatever you need, or you can order online.
    Thanks for taking the time to reply. I thought about a wireless unit, however from the information you provided, I think it best to replace the RVS camera with a newer model that the unit was originally wired and set up for the RVS. Thanks again! That helps!
  • Home Skillet wrote:
    Since you have an older RV, just upgrade the entire system.
    I bought this system a few years ago. It is truly high def.
    I wired it so the camera is on all the time. You can also turn it off with a remote fob.
    LINK
    Appreciate the link & suggestion. This RVS appears to be a similar but older unit that somebody had wired & installed in the RV. Worked rather nicely for a while. More than likely I'll go with a newer RVS unit. Thank you!
  • I checked about a new system me time ago, and was told that whatever was installed , there were adapters to allow the new system to use the old cables and plugs. Hope that helps you some. Most systems are wired to be on with the ignition, so that is not a problem. Whenever you are driving, it is on. No need to turn it off. Most larger RV supply stores will have whatever you need, or you can order online.
  • Since you have an older RV, just upgrade the entire system.
    LINK
Having RV issues? Connect with others who have been in your shoes.24,300 PostsLatest Activity: Aug 12, 2025
