1L243
Feb 03, 2015Explorer II
Update. I removed the 7 pin connector and pigtail from the truck. Peeled back all the electrical tape and inspected the connections. I found that the black w/green wire was never connected. It was taped back against the wire harness. I don't know why they would go through that when they just could have connected the wire. The truck has the towing pkg and was wired from the factory. I connected the black w/green stripe wire to the center pin on the 7 pin connector and pluged it back into the trucks harness. Tested for reverse or backup light and it works.. Now, adding a relay and running wire to the back of the trailer and connecting to ramp lights will be the next step.
Thanks for all the feed back...
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
