dougrainer
May 13, 2018Nomad
I believe I told you in your other post, the system is set up for 2 inside remote switches. The amount of wires is for those 2 different switches. You use ALL the wires for the deluxe inside remote panel. You use just the wires Biscuit mentioned for the older standard wall switch. You then set the DIP switches for the output temp you desire if you do not want the standard 120 degrees. Doug
PS, you seemed irked in another post because people were telling you not to change and you explained your wife was adamant she wanted it. Well, sorry, just because your wife wants it does NOT make it the best way to go. I hope you are honest enough to post in the future about how well that tankless system functions for her and if it REALLY meets her expectations. I have 38 years as an RV Tech and still working. I have yet to find ANY brand LP RV Tankless that I would install or recommend to my friends or customers. Just have seen to many failures.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
