BFL13
Dec 05, 2020Explorer II
Why can't the shunt go on the positive post with the pos wires all on the other end of the shunt, and with the (Trimetric case) two black wires on the outer side of the shunt and the one white wire to the inner(post side) side for measuring across the shunt going to the display as now, and the red wire that goes to the positive now go to the neg instead?
That makes a circuit for powering the display I think. Not sure about the three wires on the shunt location--would they be reversed so the white is now on the outer end and the two blacks on the inner? (to be in the same line up with the current flow)
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
