Bobbo's avatar
Bobbo
Explorer III
Aug 22, 2021
Wondering if dealer did any damage.
In 2017 when we bought our brand new Airstream TT, we had the dealer add the airstream 90 watt solar package. He did so, and we have been using it for the last 4 years. I am considering adding more solar panels to the roof, and the OEM PWM controller needs to be upgraded. I bought a Victron SmartSolar 100/30 controller to use. When I opened up the compartment, I found what I am sure is a mistake. I think the dealer mis-wired the OEM controller.
It is a Sun Explorer (not the Sun Explorer II or III). It has 3 wires (plus the ethernet cable to the display panel). The red (hot) wire is connected to the battery positive, as it should be. The black (ground) wire is connected to the battery negative, as it should be. The yellow (PV hot) wire is connected to the PV hot wire, as it should be. However, the PV green (ground) wire that should be connected to the battery negative is, instead, also hooked to the battery positive.
Of course, I am going to wire the new controller properly, but I am wondering if the solar panel has been damaged.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
