Sam_Spade
Jan 12, 2016Explorer
mlts22 wrote:
So, before I pay the three C-notes to buy a new carb assembly, is it worth tossing four ounces of Seafoam in the tank with a gallon of gas, and letting it run, or would that just waste fuel?
Yes and no.
Seafoam is overpriced for what it is.
Berrymans B12 Chemtool is a MUCH better cleaner.
Use two ounces per gallon of fuel and let it run only long enough to be sure the mix gets into the carb, maybe 30 minutes. Then let it sit at least overnight. If the problem really is deposits in the carb, that should fix you right up.
If the tank wasn't full when you started, fill it up after running.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
