RJsfishin
Jan 13, 2016Explorer
How many hrs on the gen ?
There is only one reason to ever replace a carb, and that is if it is wore out.
And wore out meaning throttle shafts and bores worn and sucking air from just too many hrs.
Otherwise I don't of anything to be gained from replacing a carb that has been properly cleaned and adjusted.
Yes, I was in the business for many years.
B-12 was very popular in the 60s and 70s for freeing up automatic chokes that had varnished up from the bad leaded gasoline in those days, and it worked instantly. W/ todays much better gasoline, we do not have near the varnishing problem anymore, so the top notch cleaners are not as popular today.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
