John_Joey
Jan 23, 2016Explorer
Sam Spade wrote:mlts22 wrote:
Thanks. That is what I bought. I'll know this Friday if that 15 ounce can lives up to its reputation or not.
It's important to note that 15 oz will only treat up to 15 gallons at the recommended rate, which is 1 oz per gallon.
If there is a problem already present, 2 oz per gallon often works a bit better.
It might take several runs over a couple of days for max. effect.
You should NOT just dump the whole can in the tank without knowing (about) how much gas is in there. One can in a full 50 gallon tank, for instance, might not do much of anything.
So what was the results you got. Was the stuff a mechanic in a can or not?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
