John_Joey
Jan 23, 2016Explorer
The reason why you decarbonize a non fuel injected engine is because the carbon gets so hot it does a pre ignition of the air/fuel mixture. That is the reason for the knocking. Ignition occurred prior to TDC causing the piston/arm to ever so slightly go backwards making the knock.
Seafoam would have done the same thing, and may or may not have been cheaper then the OEM stuff.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
