Ron3rd
Jan 25, 2016Explorer III
mlts22 wrote:Ron3rd wrote:
My 11 year old Honda EU2000 was doing the same thing and Seafoam cleared it up. Worth a try fist. Keep in mind the Seafoam might need some time to work, like a day or two.
Should I toss in SeaFoam, run a tankful through, drain the carb bowl, and when I come back next weekend, check the results? I did similar to this with the B12 (where I also ran it through, shut things off for an hour, then restarted), with not much difference made.
I would give it a double dose of Seafoam in the fuel, run it for 10 or 15 minutes, then let the Seafoam/fuel sit in the carb overnight and see what happens. Keep at it and you'll probably get it cleared out. Mine didn't resolve itself right away.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
