Sam_Spade
Jan 27, 2016Explorer
mlts22 wrote:
It will be assumed that they do the usual diagnostics to fix the issue,
BAD assumption.
You need to explain the "issue" and tell them you want that fixed.
Then if you want additional routine maintenance done, tell them that TOO. The two may not be related at all.
YOU MUST BE SPECIFIC or there is a good chance you will end up disappointed with the results.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
