Welder99
May 28, 2017Explorer
Yamaha 2000 problems
Hello all, to begin with I purched 2 Yamaha 2000 generators used very little. They came with the wire kits to hook two together . I powered both up at high rpm then turned on my AC . One generator revved up and would not power the AC . I didn't have the generators on power saver mode. They were both at high rpm at the time I turned on the AC. One generator went to yet a higher RPM. I also have a Honda EU 3000 that I hooked up and it had no problem running the AC. I used my volt meter and it showed 124.7 volts at the hook up kit. So I'm confused as to why they wouldn't power the AC . Also I have the soft start capacitor on the AC. Any input would be helpful. Thanks.
