coodle0216's avatar
coodle0216
Yamaha EF2000IS Inverter Generator ground
We will be using this generator with our 5th wheel. The instruction manual talks about a "ground (earth) terminal", and there is a ground terminal on the generator. What does this mean we need to do?? Do we need to put a ground from the generator to an earth ground or 5th wheel ground or what?? Is this something we need to use/have a rod in the ground?? Or what?? Any help/info would be greatly appreciated. Our first generator with the RV and we don't want to hurt anything.
1 Reply
  • Ignore that.
    When using your portable gen with your RV neither needs an Earth ground. If somehow you were using your portable gen to run the stick house , then maybe the story would be different , no idea, not a clue. Doesn't matter. Just plug the shore power cable into the receptacle of the portable gen (with adapter for twist lock if required or 30/15) and enjoy.
    Next you will be asking about "floating neutral" and why your three- light tester doesn't like your gen, or maybe your RV has an EMS (?) and hates your gen. There is a cure for that too. One step at a time here :)
