funk-o-meter's avatar
funk-o-meter
Yet another Onan running like **** thread. HELP!
Hi all!
Short version first:
1999 Onan MicroLite 4k
Been sitting for years
new fuel pump
new fuel filter
new air filter
oil change
pulled and cleaned carb twice
two bottles of Sea Foam
Runs like **** with no load.
Runs slightly crappy with a load. Engine "Hunts."
Long version:
Got an old 1999 Four Winds class C out of Mom's yard and have been working on it. Lots of work. Lots and lots of work. It's been sitting for at least 5 years seeing little to no action. All the fuel was varnish. Plumbing cracked. Brakes sticking, coils where shot. Same old RV Blues.
My current issue, however, is with the genset. Onan Microlite 4k. I replaced the fuel pump, fuel filter, air filter, and cleaned the **** out of the carb a couple of times and got it back up and running but it runs like ****. It "hunts" without a good load on it but runs reasonably well with the air conditioning on with only a few hiccups every now and then. Course when the AC kicks on it dips down momentarily to like 80V which also sucks.
From what I've read this points to the carb being dirty, or possibly the carb needing adjusting. So I worked on the carb... a lot. I exercised the generator several times for an hour each time. Ran like ****. So I pulled the carb off completely, sprayed and wiped the bejesus out of it. I unstuck the fuel shut off solenoid and tested it with a 12v source. Cleaned the float and needle and made sure they move well. Linkage and butterfly valves all move easily. Did all this and ran a can of Sea Foam through it in a 50/50 mix of it and high octane gas. It still ran like ****. So I pulled just the carb bulb, float and needle and cleaned everything again, did another round of sea foam and gas. Same deal. Visual and from what I can test the carb should be good.
I can't really do a carb adjustment because it's only got a throttle stop screw and a main/altitude adjustment screw on this carb. No idle adjustment screw. Also, I don't have a meter that reads frequency. I have no idea the history on this genset or if it's ever been adjusted by anyone. I do know the main/altitude adjust screw was very loose and only a few turns from popping out when I had the carb removed. And the main adjust screw "limiter cap" is missing. I followed the service manual and set the main adjust by turning it until I felt resistance, then backing it out two full turns.
Is there anything else I can do before I just take it to a Cummins repair shop? I'm about at my end with this thing. Got them Old Onan Blues. Lawd lawd....
Any advice is greatly appreciated.
  • Chris Bryant wrote:
    Those carbs are near impossible to clean- just replace it.
    Yes BUT.........
    SeaFoam is really NOT a good cleaner.
    And if you put those two cans into a gas supply that runs ONLY the generator, then that is WAY too much and might actually be causing the problem.
    If you can get a fresh supply of gas to the gen, I suggest adding two ounces per gallon of Berryman's B12 Chemtool to the gas and then run it a few times.
    Even that didn't fix mine and the Cummins/Onan dealer recommended the above.....and it wasn't as expensive as I had guessed.
  • Any of our Onans we have trouble with go to the closest Onan Coach Care. May cost a little money, but never been disappointed and they always get fixed up first time. When we bought our Alaska rig, it had sat for several years without being used. The gas had not been treated, and we had trouble with the generator. Onan fixed it up. Money well spent because it works every time.
    Dale
  • You can try searching for a carburetor repair shop but I think I'm dating myself and they're probably all out of business these days. The varnish from that old gas has plugged the jet passageways (evidently what was known as the low speed jets - on a generator like the Onan, they would be light load jets as the generator must run at a constant speed to provide 60Hz power). Buy some carburetor cleaner, disassemble the carburetor and let is soak for several hours in the solution. Lacquer thinner may be able to soften those deposits but the carburetor is formulated to do the job. After removing and rinsing the parts, blow out every passageway with as high a pressure as possible before reassembling it. Then give it another try. Make sure the hose between the fuel pump and the gas tank isn't cracked from old age and allowing air to be pumped into the carburetor instead of gas from the tank - this is a common problem on RVs over 10 years old.
    Good luck with your efforts.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
