fj12ryder wrote:
Lynnmor wrote:
I have the same awning and the screws were loose the first year, even though I rarely use it.  I looked at others and saw many loose screws.  At a minimum, remove the screws one at a time and reinstall using red thread locker.
Red? That's stud locker, you won't be removing that screw without heat and luck. I'd use Blue just in case you ever need to remove that bolt.
It will be fine, with just a thin engagement with sheet metal parts, the blue will do next to nothing, even the red will have little resistance when removing.
